2011 E350 tire pressure
Can someone tell me what the recommended tire pressure is for a 2011 E350 Luxury Sedan per the fuel filler door label? 17" tires all the way around.
Thanks!
Thanks!
I have a 2011 E350 Bluetec that I removed the run flat tires off of and put regular tires on it which you would normally find on a non-Bluetec.
I am assuming that the tire pressure listed on the fuel filler door would be different from a Bluetec and a non Bluetec.
Maybe someone with non-run flats can tell you what their stickers say.
I have the 18" so can't really help you.
I will post an image of the fuel door for you to see, first off mines are 17" .I set the pressure for front 38 psi , rear 42 psi
I know fully loaded maximum pressure for rear tires are 48 psi
, sounds a lot lol
Good news, I have just done some research and come across this image below :
It's exact of what I talk you about :
![](http://www.mybenz.org/zoopp/html/uploads/img4e6ecb1c29781.jpg)
And, you can see W212's fuel door
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
