Should I lower with 19" ?
Would lowering be necessary, or will 19" satisfy? Just looking for a clean, original flush look.
Thanks.
http://www.oemwheelsplus.com/index.p...heels-set.html
I have seen w212's with 19" and still notice the gap in rear... so wasn't sure if lowering is common sense when moving up in size ?!
for Brand New Set of Four (4) GunMetal Machined Face
19" AMG Style Staggered Wheels
w/ Center Caps Included
709.00 really ??
it looks like some Chinese copies to me ...
I think I may just keep the original wheels and maybe refinish them in a different color.
It's a balance between ride height and "flush" wheel/tire fitment to achieve the perfect look you are going for. Too low of an offset and too "square" of a tire will have you rubbing. Too high an offset and too "rounded" a tire will have you wanting to drop more.
It's best to take some measurements of the current setup and then use a wheel calculator to find out what some different results may look like.
why i should buy 60k+ car to use some Chinese knock off wheels ??
noone knows OE source for wheels online ??
like BMW has
getbmwparts
tomkinsonbmwparts
Tischer BMW
etc etc
Here a pic:
If you get a chance, take a picture of the rear wheels before its lowered..curious about the gap currently w/o it lowered..
thanks
Attachment 447783
! It does not look bad at all w/o it lowered.. !
45 offset, correct ?
But no this car isn't lowered, but the way I'm going to do it to mines is a guy i know he use to work for a mercedes dealership here in my country but ended up opening his own shop and he can lower it with the mercedes computer (i think it called the DAS or something) he did it to a friend of mines, pretty clean and doesn't need any additional parts or anything removed, he can put it at any level. I'm suppose to go today to tell him if i do ill try to record the process.
(sorry for any bad grammar, write better in spanish
