Sponsored by: CARiD
rear view mirror tilt on 2014?
Old Nov 9, 2013 | 03:07 PM
PeterUbers's Avatar
I have the parktronic with surround view -- when I hit the R passenger mirror button, and in reverse -- shouldn't it tilt down? is there a setting for this or is this a deleted option if you get surround view?
thanks
Old Nov 9, 2013 | 07:27 PM
martinlarose's Avatar
2025 e 450
Peter you have to program it. I can't quite remember how but if you google it i believe it will tell you how to do it
Old Nov 9, 2013 | 07:52 PM
pdjv's Avatar
2011 E550, 2008 SL55 AMG
Not sure if the 2014 menu system is the same, but on my 2011 I use the scroll-right button on the steering wheel to get to the "Settings" menu and scroll down to the "Convenience" section. The mirror option should be in that group. Turn it on, adjust the right side mirror to the position you want when backing up, and save the setting - should now work automatically.
Old Nov 9, 2013 | 08:12 PM
YYZ-E55's Avatar
MY17 E43 Matte Selenite/Macchiato Beige, MY16 GLE350d Tenorite/Crystal Grey, MY17 B250
With the car in reverse, press the right mirror button (if not already illuminated) and adjust the mirror to your liking.
The mirror will automatically retain this setting for future reversing, so long as the right mirror button is active. If you select the left mirror button to make changes to the mirror settings, you must press the right mirror button when you're done to enable the tilt feature.
