Anyone running 285/25/20 rear tires on a 2010 w212 e550
Hello all,
Here is what I have planned Front: 20x8.5 245/35/20 tires front Rear 20x10 5x112 275/30/20 tires Tire shop suggested 285/25/20. Does not seem like enough sidewall. If that will not work any suggestions? |
BUMP> Plz help.
First of all, what are your offsets for the wheels? I'm running front:235x35x20 on a 8.5 wide wheel with -35 offset, rear is: 275x30x20 on a 9.5 wide wheel with the same -35 offset. Front and rear is real flush with this setup, -38 or -40 would probably be better for me since I am lowered quite a bit, but I still don't rub. Do a search in this forum on,"20" wheels", plenty of posts and answers out there.
I'm running 42 offset front on 20x8.5 and 55 offset rear on 20x10 wheels.
Originally Posted by hukfesq
(Post 5888717)
Hello all,
Here is what I have planned Front: 20x8.5 245/35/20 tires front Rear 20x10 5x112 275/30/20 tires Tire shop suggested 285/25/20. Does not seem like enough sidewall. If that will not work any suggestions? I would go 20x9 35offset front with 245/30/20 tires and 20x10.5 40offset rear with 275/30/20. |
I would read this it might help. Running the tires mentioned above from D&g might be little off from the factory tire diameter and really throw things out of whack, not sure but check out my post and read the comments.https://mbworld.org/forums/e-class-w...ire-sizes.html
Thanks guys!!
Anyone use loctite in their wheel lugs?
Anyone tried offsetting on a 4Matic? In pondering what to buy for my summer tires in a couple months. I am driving an e550 4Matic.
