E350 Failure
When I returned home, I took the car for service, reported the failure, and had it inspected. They found nothing.
Over the next few months, I encountered problems periodically on initial startup. The car starts but displays a variety of problems on the DIC. Prominent are front suspension malfunction, SRS malfunction, cruise disabled, etc. The seat adjusters will not work and the car will not shift into drive or reverse. The frequency of this happening and the number of times the car needed re-starting to then work, slowly increased.
A couple of weeks ago, I returned to the dealer to have it looked at. They stated they made some programming changes and re-booted the computers, BS I assumed and told them as much.
Six days ago I returned the vehicle to the service department. Nothing had changed and the problem persists. They now tell me they have re-created the problem but have no answer. They have opened a case with Mercedes and are working on a solution.
I am well aware of the "Lemon Laws" and really don't want to get into that discussion at this point. My question would be if anyone has had a similar problem and the cure if any. Thanks for any input.
Sounds like you may have knocked something loose when hitting that hole. Roads here in Ohio are starting to look very ugly this winter and I'm nervously darting back and forth to avoid all the holes.
