Sponsored by: CARiD
2012 E Class gas cap replacement
Old Feb 1, 2014 | 11:43 AM
cepal's Avatar
2014 E250 Bluetec 4MATIC
Hi,
I need to replace the gas cap of 2012 E 350. I am having hard time figuring out how to take the gas cap strap out. It is fitted with a plastic head. Should I just pop it out with a screwdriver? I I tried with gentle pressure and it didn't work. Didn't want to break it.
Any help would be greatly appreciated!
Thanks!
Old Feb 1, 2014 | 11:58 AM
Eayacht's Avatar
2003 E320 W211
Hi. Tried to find it on YouTube but no luck. Best bet call the dealer and ask the parts dept, they should be able to explain how to replace the gas cap with out breaking it.
Good luck!
Old Feb 2, 2014 | 10:15 PM
cepal's Avatar
Found the solution
It is like S class someone posted in a different thread. The plastic head of the strap retainer has a small plastic pin in the middle. Push with a paper clip and it comes out through the back part and the head comes out.
To put it back, put the head through the hole in the strap and then push the plastic pin through the hole in the middle.
Thanks!
