Originally Posted by alanme123
(Post 5958889)
Guys, I'm sure that keyless go locking ONLY works on the little small squares on the door handles. That is what it is for. My car won't lock unless I touch that small square.
I originally thought I had to press the small square on the door handle to lock the car. Then I realized tapping anywhere on the door handle worked fine.
Pressing and holding the small square does invoke the "close all windows/sunroof". I can also do this by holding the lock button on the key fob. To "open all windows" I hold down the unlock button on the key fob. Is there a way to invoke "open all windows" except with the key fob? |
Originally Posted by thenew3
(Post 5959397)
Hmm, not how its working on my car. I have key in my pocket, standing next to drivers door, My wife and/or my son can unlock it by pulling on the handle on the passenger side front or rear doors. Same thing for the rear hatch (its a wagon), I can stand by the drivers door and wife can pull on rear hatch and it'll automatically unlock and open (along with unlocking all doors).
The only thing I can add is that whoever changed from the nice beep to the generic horn door lock confirmation from MY2010 to MY2011 should be fired at MB. I hate that change!
Originally Posted by shashivr4
(Post 5959215)
The little square that is the same color as the car's paint (not the infrared square). I tried to close the windows by pressing on it for a few seconds and it indeed does work.
Originally Posted by Arrie
(Post 5959523)
In my car I have to unlock the doors with the button on the door to let others enter on the passenger side. Or if I unlock from the driver's side rear door it unlocks everything. I have it set so that when I touch to unlock the driver's door the other doors do not unlock. If I want to unlock other door I have to do it using the rear door.
(Post 5959390)
make sure to run around the car clockwise once first, then wave your foot under the rear end....THEN swipe :)
Originally Posted by pamiboy
(Post 5960445)
I would like to have this setting. How can I get it? Currently all my doors unlock if I touch the driver side door handle.
Thanks a lot.
(Post 5960445)
Originally Posted by drsaab
(Post 5959541)
(Post 5959541)
Originally Posted by mikeyle
(Post 5962608)
you can change it by scrolling through the options menu using the steering wheel, im pretty sure its near the menu for controlling the ambient lighting also.
(Post 5959215)
Ok newbie question here... Please don't flame me. I just bought my 2011 E350 BTC. It's a sport, P1. I do however have the infrared sensor on my handle. At this point I have only used the keyfob to lock and unlock the doors. I do not have push button start or anything and see not mention of keyless go. My question is: Is my car still equipped with the ability to lock and unlock with the handle that you guys mention? Is this a feature on all E350s? We are on vacation for a week, so I can't run out and try!
Originally Posted by The Ryno
(Post 6031136)
Regards, Don |
(Post 5960586)
Hold both lock and unlock buttons down at the same time for 6-7 seconds until the light on the remote key blinks. I'm not sure if you need to be next to the car when doing this. This procedure changes the unlocking to I think they call it "local" mode where only the driver's door and the fuel door unlock. You can still unlock everything by doing it at any other door than the driver's door like I try to remember to touch the rear door if someone else is to enter the car with me.
Sweeeeeet!!! |
(Post 6031136)
Originally Posted by thefisch
(Post 6031242)
The answer to the second part of your question is no - that feature of unlocking and locking by touching the handles is a feature of keyless-go which is part of the P2 package in 2011. Keyless-go also gives you push button start. The infared sensor on the driver's door is unrelated to keyless go.
Originally Posted by belarus27
(Post 6031246)
I think that infrRed is to open/close windows... only. Dont know any other use of it.
(Post 6031246)
Keyless
As far as I know you have to touch the square pad on the door handles to lock it. I have never found it possible to lock it by repeating the unlock step.
I suspect when it locks you actually touched the pad.
(Post 5958573)
I am able to unlock my vehicle with the keyless entry system by simply placing my hand on the door handle. However, when it comes to locking it, it doesn't work as well. Sometimes it locks, other times it doesn't. Am I just not putting my hand in the right location? Is there even a specific location to unlock versus lock?
Thanks in advance! |
(Post 6031246)
TToe550 you are wrong for a 2014. The square on the outside does lock all of the doors when you get out. But you have to only hit the square on the handle. On your 2010 it may work for the windows and sun roof but on the 2014 it locks the doors. And it really does work. It is also in the manual.
