Sponsored by: CARiD
ML wheels on an E350?
Old May 1, 2014 | 11:49 AM
carsandcapp's Avatar
E350 Bluetec
Found some 20" factory wheels from an ML 350 with 265/35 rubber all the way around. Will they even fit on my E350 or just a bad idea all the way around? I am new to the MB, coming form a BMW 5 series that have 19" wheels. And yes, ride comfort does matter to me. Don't want to be subjected to a super harsh ride, but would not mind getting rid of some of the "plush" feel I am getting now. Thoughts?
Old May 1, 2014 | 11:57 AM
YYZ-E55's Avatar
MY17 E43 Matte Selenite/Macchiato Beige, MY16 GLE350d Tenorite/Crystal Grey, MY17 B250
The wheels might work but the tires are way too tall.
Old May 1, 2014 | 02:34 PM
E350 Bluetec
Tall or wide? 35mm is not much sidewall height, at least in my book.
Old May 1, 2014 | 02:49 PM
diesel_power's Avatar
2011 E220 CDI
The AMG cars usually run a 255 tire on a 19 inch wheel in the front - and they have slightly wider front fenders. So I don't think a 265 tire on a 20 inch rim will fit on a standard E350.
The wheels may fit - but you have to get the correct size on the tires.
Good luck!
Old May 1, 2014 | 03:00 PM
YYZ-E55's Avatar
The sidewall isn't 35mm tall, it's 35% of 265mm = 92.75mm
4digital's Avatar
2012 E350
Edit: removed... YYZ posted the same thing at the same time!
Old May 1, 2014 | 03:39 PM
E350 Bluetec
yep..you're right.
Smaller tires...both ways in order to give it a go.
Old May 1, 2014 | 06:52 PM
RSIKR's Avatar
2014 W212 E350 4M
The circumference or diameter of the current tire and wheel combo has to duplicate the replacement. I believe the diameter of the E350 4Matic tire is 25.7" whether it is the 17" or 18" wheel. The profile is the difference. the profile is the percentage number after the width and before the wheel diameter. You can research the diameter by looking up your present tire on Tire Rack. If the lug bolt pattern is not the same on the ML wheel it may not fit. Screwing around with different size wheels is fine for tuners but is probably not what the car was designed with in mind.
245/40 R 18 97V
245 width of the tread, 40 ratio, R for radial (redundant as they are all radials) 18 wheel diameter, 97 load rating in this case 1690 lbs, V speed rating V is 149mph. Tires also have markings for treadwear, traction and temperature range.
