Sponsored by: CARiD
2011 E 550 BRAKE PADS
Old May 27, 2014 | 01:10 PM
DENNISE's Avatar
2011 E 550
What is the complete procedure involved in changing the front and rear brake pads on my 2011 E 550? And, what brand of pads do you suggest?
Old May 27, 2014 | 03:23 PM
pdjv's Avatar
2011 E550, 2008 SL55 AMG
Unless you're doing something more than just normal street/highway driving, OEM pads are the best. If you're trying to avoid (or reduce) brake dust do a search - there are other threads on that.
For procedures, you can go to www.alldatadiy.com and http://www.startekinfo.com/StarTek/ - AlldataDIY costs about $13 for a 12 month subscription for one car. You can buy one-day access to StarTek Info for about $20. That said, if you've ever changed pads before, you probably don't need much additional information.
Old Jun 24, 2014 | 09:29 AM
BMWtoAMG's Avatar
Previous: 2011 E550 4MATIC Current: 2018 AMG C 43 Coupe, 2021 GLC 300
I know this thread was a few weeks ago, but I changed my front pads last night, and outside compressing the pistons (the curves made it tough to use your typical AutoZone tool) it was by far the easiest brake pad swap ever.
I have WIS, but it wasn't necessary. Picked up OEM pads from dealer as they were competitive with online pricing. You don't need to touch the caliper. I unplugged/removed the sensor after seeing it was not necessary to remove the mounting bracket. Punch out the two pins holding the compression spring, then back the pads out. Mine had meat left, so it was snug.
Reverse it and you're finished. Good time to scrub the inside of the AMG wheels, squirt a little WD40 on the lug bolts. Wash all the crud off your hands/arms, then bed those new pads in.
