Sponsored by: CARiD
Adding cigarette lighter socket to center console
Old May 29, 2014 | 05:38 PM
JohnAJohnson's Avatar
2014 E250 Bluetec
The center console (under the arm rest) of my 2014 E250 Bluetech has a Media Jack and a USB Jack, but no 12vdc cigarette lighter socket. I like to keep a cell phone in there and keep it on a charger, hence, the need. I know the USB port provides charging voltage but I'd like to keep that available for a USB stick containing pictures, mp3's, etc. I've seen where the lighter socket (same one as the trunk and back seat ashtray) is available, but haven't seen where anyone has installed one in the center console. It looks like there might be enough depth right next to the USB and Media Jacks.
Anyone done this? And if so, can you provide any tips on console removal, etc? Thanks in advance.
Old May 29, 2014 | 07:51 PM
thefisch's Avatar
Top Answer: 1
2011 E550 P2 4M Sedan
check out this thread. The OP was looking to do something similar. You may want to see if they did it yet.
Old May 29, 2014 | 08:37 PM
RA72825's Avatar
I have a 12V socket in the glove compartment. Do you have one and would that be convenient for you?
Old May 29, 2014 | 08:44 PM
2014 E250 Bluetec
Thank you Fisch.
It would indeed, but the glove compartment cigarette lighter socket was removed in the 2014 facelift (as I understand). Unfortunately, mine doesn't have one.
Old May 29, 2014 | 09:47 PM
thefisch's Avatar
Top Answer: 1
Originally Posted by JohnAJohnson
Thank you Fisch.
No problem. So the 2014 only has two 12v outlets - the cigarette lighter near the cupholders and the rear center console? I thought they moved the glovebox 12v to the center console. Guess they didn't.
Old May 29, 2014 | 10:14 PM
RA72825's Avatar
I have the one in the trunk as well, so 4 altogether. I don't use any if them. The socket really does belong in the console.
Old May 29, 2014 | 10:32 PM
thefisch's Avatar
Top Answer: 1
Forgot about the trunk. I agree that the console would be more convenient. My last car had that and I could keep the cable tucked in there and connect when needed. Now I just use the rear AC jack and run the cable alongside the passenger seat for use when needed. At least I don't see it all the time.
Old Jun 27, 2014 | 08:51 PM
2014 E250 Bluetec
I've found that none of these outlets (trunk, rear seat, or drivers lighter) have power with the ignition off. I need an "always on" source to keep the cell phone plugged into. Is your glove compartment lighter socket "always on"? If yes, I think I'll install one there in my 2014 since there is obviously a 12v source nearby that's always on.
Currently Active Users Viewing This Thread: 7 (0 members and 7 guests)
