Sponsored by: CARiD
2012 E350 Bluetec - oil filler cap - no gasket
Old Jun 19, 2014 | 07:01 PM
btesar's Avatar
W126 1987 300SDL
I noticed as I was detailing the engine today that there was oil pooled between the filler cap and the rubber surround. I took the cap off and noted that there is no rubber gasket on the filler cap. Can anyone check their car to see if I'm supposed to have a gasket there to prevent seepage?
Old Jun 19, 2014 | 09:29 PM
fintail's Avatar
S213 E450 4Matic, W111 220SE - prior cars: 3x W212, W210 E55 AMG, W202 C43 AMG, W126 300SE
My car does not appear to have a gasket. If there is one, it is inset below the lip of the filler cap, and is hard. My garage is fairly dark, so I am not 100% certain, but there was no soft gasket.
Old Jun 19, 2014 | 10:53 PM
DerekACS's Avatar
2015 E250 BT 4M
E350 BT oil filler cap
Correct; there is no soft gasket. As the cap is turned clockwise, it seems to tighten its seal. No seepage observed around my engine's filler cap.
Old Jun 20, 2014 | 09:43 PM
btesar's Avatar
W126 1987 300SDL
Thanks. I'll check it in another 1,000 mies. It's possible the dealer spilled it on the last oil change.
Old Jun 23, 2014 | 05:51 PM
Mbenz260e's Avatar
2022 E450 Prior:2021 S580 2012 E350BT, 2013 GL350BT, 2009 ML320BT, 2006 E320CDI, 1987 260E
That's likely what happened does it seem like fresh oil? Diesels make the oil dark black right away.
