Removing engine and battery covers
1. Remove the engine cover?
2. Remove the battery cover?
The battery cover is even easier. The air intake box is held on by three clips - left, right and middle. Just remove the clips and lift it off. Battery is right underneath that. When you put the intake box back be sure to line up the slots on the bottom along the back side. It should rest in place (not fall or sag) before you hook the clips back on.
Will try the battery cover though. To me, this may help with getting it tested and replaced by Advance or Auto Zone or Sears later.
Do appreciate the information. Interesting that M-B would be so much more complicated than every other auto manufacturer for some things that should be simple. Cabin filter is another one.
