ECU tune help?
1. I know that once you tune an ecu your powertrain warranty goes out the window.my question is, is the warranty only voided when the tune is active, or let's say I have flashed back to the original factory settings, will the warranty be back into play,or is it completely shot?
2. Let's say my engine decides to self detonate, and I flash it back to factory settings before taking it in to the dealer, Is there a way that MB can tell that your car was previously tuned? Does the ecu log when it gets flashed? To sum it up, does the tune leave any kind of previous history like top speed or anything like that?
regarding your question , if you flash back to stock you should be good , according to all readings I did. correct me if im wrong ppl.
This is the tuner, connects to your phone,and from there you have to get a app that has your tuned files to upload into your car!
http://oetuning.com/blog/?p=1010
Honestly I can tell you after the tune the car felt allot better, car wasn't as sluggish, power down low, and gained a bit if high end power as well! Before the tune, it was a monster of a car, after, it was a whole new beast!
