Sponsored by: CARiD
Windshield washer tank leak E350
Old Oct 22, 2014 | 12:27 PM
2010mercedes's Avatar
e350
My 2010 E350 has a windshield washer tank leak. How do I access tank to inspect. Are the any common problems with these tank leak. Thanks
Old Oct 22, 2014 | 01:02 PM
ECSTuning's Avatar
Former Vendor of MBWorld
2012 SLS AMG
2010mercedes,
It is not uncommon for these washer tanks to break and cause a leak. Due to the number of variations on the part based off of codes associated with the vehicle, if you wanted to PM me your VIN I can look up the correct part for you.
If you are trying to inspect the tank first, you are going to want to remove the wheel and pull the front portion wheel liner to inspect the tank. You may also have to loosen or remove the front most belly pan.
If there is anything else I can help you with please let me know.
David
Old Oct 24, 2014 | 01:20 PM
steinjr's Avatar
Veteran: Army
2015 S550 4MATIC
I had this happen to my SL model and it was the o-ring on the pump that went bad causing the leak. The tank was fine.
