Survey on ARRIE MB Fanatic
![](https://mbworld.org/forums/images/ranks/veteran_navy.png)
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
1. Should a Mercedes Benz Fanatic by the name of Arrie be able to post on this web site to tell another member to Shut UP because Arrie does not want him to complain about his cars navigation?
2.Should the webmasters on this site ban or suspend ARRIE from further posts.
3. BY checking prior posts of ARRIE you will see that ARRIE has done the same or similar to other members and should he be allowed to continue?
You should read your own posts before criticizing others. I never called you a "wimpy idiot" but you seem to think it is ok for you to call me that.
If you read all of my posts over they three years I have been on this forum you might realize that I actually may even have helped some folks around this forum. I don't remember one single post from you doing so. Only bad negative comments about the car and then strong criticisms against anyone who does not agree with you. Like you talk about a minor navigation glitch under MR reliability.
You also started bad mouthing about me when I said that I bought the sun glass holder thru my dealer pars department when you was not able to do so. In your super man brain I must be telling a lie because you cannot order that part from your dealer so everybody must have the same situation. Well, I was able to order it, period.
You also said in your latest post about the navigation that you tried that but it did not work. If you mean you tried to save your car position as home position when the car was at home then you have no idea how to use the navi system in your car. Or the system does not allow saving any position but by your posts the issue is only with your home location so you probably don't know how to use it.
I'm pretty much done with this forum. I have better things to do than argue with a pest like you. Have a good life with the car you regret so badly buying. I guess you can't afford owning it and that is your real problem.
'15 E350 4M Sport
The intent was for a poll. I wish there was an ignore button or a block button for certain members but I cannot find it. I will have to just try and Ignore this bad one on the forum. It is a shame how some people get their kicks. I tried to embarrass him but a person like him just does not get it. This forum is meant to help not make fun of someone. I hate stooping to his low standard but it aggravates me when someone thinks they are above everyone else. Oh well such is life.
1 Post
2014 E350, 2012 SL550
2. Select "view public profile"
3. On his public profile page click on "User Lists"
4. Select "Add to Ignore List"
Regards,
Don
Dfordham. Thank you very much. I just did what you explained for me to do. I had no idea you could do. A million thanks I no longer have to put up with him and his remarks. It is good to have members like you.
Administrator
OK,
You have issues with someone you click the report to moderator button or ignore them. If you don't know how to do something (ignore), you search or ask (after you searched).
Starting this type of thread will not solve the self perceived issue.
Closed
Closed
