Sponsored by: CARiD
Hot brake rotors and big puddle...
Old Feb 16, 2015 | 06:56 PM
cybertronicify's Avatar
2003 S430, 2014 E350
Hello everyone! I just got off the mountains with my buddies and my brake rotors were very very hot. We had to cross a big puddle of water and the right two brakes were smoking (steam). Did i do any damage to my brakes? I went slow across the puddle... I've heard that it can crack the rotors or even warp them, is that true?
Old Feb 16, 2015 | 07:22 PM
homeofstone's Avatar
2011 E63, 2011 Hyundai Genesis 4.6 v8, 2013 GMC Denali XL, 1965 Ford Mustang, 2005 Merc. E500
I think you should be ok.
Old Feb 16, 2015 | 09:45 PM
This is a lease car and if i did damage the rotors, do you think my dealer will cover that?
Old Feb 16, 2015 | 10:40 PM
I have no idea. It depends on what is in the lease contract. Read your contract carefully and you may find your answer.
Old Feb 16, 2015 | 11:17 PM
Ok. Thanks!
Old Feb 17, 2015 | 12:11 AM
Arrie's Avatar
Ok. Thanks!
First off, the brakes on any car should not get damaged by driving thru any kind of condition on the public roads.
It should not matter what the lease contract says. If your brake rotors fail under normal driving then MB warranty should cover it.
Did you damage the rotors or is it just that you saw water steaming off of the rotors?
Old Feb 17, 2015 | 12:18 AM
I was riding on the brakes down the mountain and went through freshly melted snow water, it formed a pretty big puddle. Steam came up the right side of the car, so i guess it was the brakes? or was it something else... The car drove home perfectly, didn't feel a difference.
Old Feb 17, 2015 | 12:44 AM
Arrie's Avatar
Steam comes with heat usually higher than 212 F. On mountains at higher elevation at lower temperature.
I don't think you have anything to worry about.
Old Feb 17, 2015 | 01:59 AM
Ok, Thank You! Just worried that the dealer would try to charge me. Service B is coming up, i'll see what they say.
Old Feb 17, 2015 | 05:12 AM
optimusprime m1's Avatar
W124 260E
No defferance then there is not a problem . If they warp you would feel it as you use brakes .
Old Feb 17, 2015 | 01:53 PM
RA72825's Avatar
My guess is the steam you saw come out from under the car was due to the water hitting the Catalytic converter(s). This happens all of the time as the exterior temperature of the CC can easily exceed 800 degrees. It immediately will produce the steam you saw. I don't think it had anything to do with your brakes at all.
Old Feb 17, 2015 | 02:37 PM
rediesel's Avatar
2006 E320 CDI 2014 C63 507 Coupe 2012 E550 4M 2016 E63s Wagon
In the USA pads and rotors are consumable items and unless there is a defect/recall they are not covered by warranty or pre-paid service.
Old Feb 17, 2015 | 03:17 PM
noka's Avatar
'24 Porsche Macan
In a past C, I had rotors and pads replaced for a problem under warranty. However, in the case of wear or 'abuse', of course warranty would not cover it.
Old Feb 17, 2015 | 04:07 PM
rediesel's Avatar
There are instances of defective parts being replaced (such as the TSB replacing squealing pads in my 507).
Majority of owners who wear out (or abuse) a set of pads and rotors will be responsibility to pay for replacement.
Old Feb 17, 2015 | 10:21 PM
Cocca's Avatar
2019 Land Rover Discovery 2018 BMW 540ix 2013 Land Rover LR4 2007 Porsche Carrera 4S Cabriolet
More likely than not, the steam was from the engine under-area and/or hot exhaust components (any of them) getting splashed with water.
More likely than not, if your rotors crack - lease or no lease, they're a wear item and not covered by a typical warranty. More likely than not, your rotors will not crack.
