Battery Replacement
2011 E550 P2 4M Sedan
Advance and AutoZone have some good copuons from time to time like that $50 off. Perfect for a battery replacement. And their warranty is better than MB replacement battery. Usually full replacement for 3 years and then maybe some prorate warranty up to 5-6 years total.
Yeah, the 3 year full replacement is a good warranty and longer than MB and Interstate. Plus the Interstate and MB batteries are considerably more expensive than the Duralast Platinum and its counterpart from Advance.
W212 Sunroof motor repair
My W212(E-class) sunroof wont' close. And I found that the motor drive gear went bad, actually broken away.
So, I purchased the replacement gear through online shopping.
However,no information is available how to assemble the gear to the motor shaft.
If there is anyone who knows how to handle it, please send email me to manfinder1@gmail.com.
#32
1996 C280, 2010 E350 Previous: '52 300 Adenaeur, '59 220 S, '94 C180, '03 C320 4-Matic Sport
I was thinking of connecting an old - but charged - motorcycle battery thru the 12V charging port between the front seats to maintain a charge while swapping out the old battery for a new one. This way, I figure I will not loose any settings.
By the way, since we don't drive our E350 much, we usually keep a solar trickle charger plugged into the same 12V port between the seats, and it seems to help a lot.
Any comments?
Any comments?
I finally changed out my Battery to a Duralast Platinum H8-AGM this week. My current battery had met a slow death. $175 at Autozone.
This is a 900 CCA Battery with a 160 reserve and is a monster.
There is no magic to swapping in this battery other than it weighs a ton and swinging into place is a back breaker. Took 15 minutes.
My clock needed to be reset and that was the extent of it. No lost information, presets, or anything else. An easy job for anyone and no need to pay a higher price for a dealer to install. It has a 3 year full replacement warranty, which is good for me and better than the 2 year MB warranty.
#33
#34
Any comments?
Any comments?
