ESC Inoperative Error
The car basically feels like it hits a wall when this error comes on. I have to pull over to the side of the road and restart the car. All then returns to normal.
This has happened to me 2 times on dry road and 1 time on wet road. I guess the wheels slip when accelerating too hard thereby causing this error?
I'm not sure, but it's dangerous for the car to just suddenly slow down like that when the error does occur.
Have you had it checked out?
My car is Renntech tuned so I'm not sure if that makes a difference with what is happening...
Do you have the equipment to reflash the stock tune and test to see if the same error occurs? If you don't get the error without the tune, then you know there must be some conflict with the tune when ESC tries to do it's thing. If the same error happens, then your ESC could be bad.
Also, do you know if our cars warn us if we have a low battery? This is my first Mercedes.
There is no warning for low main battery. I have to jump my car a few times already. Comand will give you a warning if you continue to use it after the car is off. However, I gotten that warning and had no issue with starting the car later on. My battery escapades are documented in some other threads on here.
There is an auxiliary battery in the dash for the electronic transmission shifter. The car does give a warning to replace that. So far (knock on wood) I haven't gotten that one.
I know where you're coming from - if the light isn't on when I take it in then I am usually wasting my time.
P0872 (0872) Fault of function monitor in electronic accelerator (p2638).
I know from prior research people with this same esc inoperative error had it fixed by changing the accelerator pedal (gas pedal) or steering angle column sensor. It seems the code above points to the pedal? The tech didn't know offhand so he said he would do some research and get back to me.
Any ideas or thoughts on the code? I also read that the mass airflow sensor could play a part...
Do you also have that?
If not you just need a new accelerator pedal ... Should be under warranty
Sprintbooster will be a small piggyback looking cable to the side of the pedal... It can be very discrete
If steadfast in replacing, accelerator pedal is part # 2043001104 (confirm with VIN).
How hard is this to do myself? I'll look for a YouTube video.
