Lowering and Ride
Are you happy with ride? On some of my other cars- Jag and NSX ride actually improved since springs are progressive.
Feedback?
with your question. if youre not slamming it, I reckon you should be alright. 1" to 1 1/2" will give you better handling due to lower center of gravity.
IMHO. The drop made the car handle allot better than the stock 18" AMG wheel at stock height. No rubbing no matter how hard you take the corner.
Good Luck.
This looks the best. H&R's look a little too low for me, but these look perfect. Are these the Eibachs?
Thanks to this post answered all my question.
But I also have question about Rims and Tires.
I am looking into Niche Misano M116
Bolt Pattern 5x112
Front Specs 20x9 Off Set 32
Rear Specs 20x10.5 Off Set 27
Tire
Front 255/35R20
Rear 275/35R20
Don't know if this will work on E550 ?
So you actually got the Sport springs 1.4" and 1.3" drop where as the Pro Kit is 1.2" front and back. I wonder if there is a difference in compression rating between the Pro and Sport.
Here you go:
20x8.5 44mm offset
20x10. 55mm offset
245/30/20
275/30/20
I believe you need to have links in the rear for the E550 and not springs so specs. should differ.
The above setup is for the E350 IMO is perfect. No rubbing, no need to roll the fender and most importantly of all, no bouncing.
Good luck.
Guys you need to keep in mind where you live does matter on your wheel/tire setup. I live in SoCal and the roads are decent where as I read in the Midwest, some roads are rough and can bent the wheels easily so your tire would need a little more diameter around the wheels to better protect the wheels. Hope this helps.
One great thing and the best I found is like for Vossen, you can contact their customer service and tell them the year, make, model and where you live and they can tell you exactly what setup with or without lowering it to get the best out of your car.
Good luck.
Here you go:
20x8.5 44mm offset
20x10. 55mm offset
245/30/20
275/30/20
Good luck.
Thank you for the info.
Btw, is your E350 4MATIC ? or RWD ?
