Sponsored by: CARiD
Turn Signal Question (not working unless car is turned off and on)
Old Jun 29, 2015 | 07:09 AM
claudef's Avatar
2013 E350 & 1996 SL320
I did not find any post discussing something similar to what I am experiencing.
This weekend, I took a long drive (4 hours all interstate) after about 2 hours, I notice the turn the signal would no longer work (small tap right or left or engaging the signal completely would result in nothing, no blinking light or relay noise).
I turned on my warning lights to check if it was a relay, but they worked fine. I stopped the car, turned off the engine, turned the engine back on and they worked fine after that. On the way back, same thing, about 2 hours into the drive, no blinkers, warnings worked. Stopped the car, turned engine off, then back on and they worked.
Any idea what this could be? Thank you in advance
2010 E350 4matics
Old Sep 14, 2015 | 01:23 PM
claudef's Avatar
No one had that issue??
2010 E350 4matics
This happened again today. Turn signal stop working. Wipers worked, brights worked. I turned the engine off and back on and turn signals worked again
Something gets reset. The dealer want to replace the entire module but they are not sure if this will fix it because they have not heard of such a problem. Also, no code present
Old Sep 14, 2015 | 01:25 PM
YYZ-E55's Avatar
MY17 E43 Matte Selenite/Macchiato Beige, MY16 GLE350d Tenorite/Crystal Grey, MY17 B250
When the turn signals stop working, does the hazard light switch work?
Old Sep 14, 2015 | 01:28 PM
claudef's Avatar
Yes, the hazard light switch works perfectly when this happens.
Old Sep 14, 2015 | 02:26 PM
thefisch's Avatar
Top Answer: 1
2011 E550 P2 4M Sedan
Does the exterior turn signal light still work even though the dash light/sound does not? Replacing the module seems the best course. Do you have CPO or other coverage?
Old Sep 14, 2015 | 02:31 PM
claudef's Avatar
No exterior light and no interior signal indicator showing. But a reset fixes everything
