Sponsored by: CARiD
AMG Double-Spoke 18 vs AMG Triple-Spoke 19 fitment
Old Jul 12, 2015 | 06:37 AM
lzamora's Avatar
958.2 Turbo, E420 W124 94, 525i E34 91, C4 Corvette 86, R230 SL500 07
Hello guys!!!!
I'm living in the Middle East and got myself an E300 Avantgarde W212 2013 with the AMG package. The Datacard shows Avantgarde/Standard Suspension code 677. The wheels installed are the AMG Double-Spoke 18" with mixed tires (AMG Styling IV). Supposedly the front ones are 8.5 x 18 ET 48 and the rear ones are 9 x 18 ET 54.
As far as I googled, it says that "The tire dimensions reach from 245/40 R 18 for the front axle to 265/35 R 18 for the rear axle in case of mixed sets of tires"
I would LOVE to upgrade the wheels to the AMG triple-spoke alloy wheels. I have found them in two versions:
Front wheels AMG Styling VII - 8.5 x 19 inch ET43
Rear wheels AMG Styling VII - 9.5 x 19 inch ET43
https://www.kunzmann.de/shop/en/tire...gn-19-inch.htm
By running an offset calculator, with the ET 43 on then back and 265/30 19 x 9.5, the package will only go 11mm out, which they claim it's acceptable for most cars.
http://www.wheel-size.com/calc/?whee...=30mm&scl=50mm
or (used on the R231)
Front wheels AMG Styling VII - 8.5 x 19 inch ET30 (Part Number 2304015402)
Rear wheels AMG Styling VII - 9.5 x 19 inch ET31 (Part Number 2304015502)
http://www.alloywheelsdirect.net/mer..._vii_wheel_486
With a such low offset I will definately have problems.
Now the problem is that I cannot find the part numbers for the wheels in ET43.
Does anyone know if they really exists??? I haven't emailed to ask them if they are OEM of replicas...
Thanks a lot for the help you gurus could give me!!!!
