20" tire size help!!
E350 20” Wheel Specs
Wheels:
20 x 8.5 F et34 235/35
20 x 10 R et40 275/30
NO Rubbing!!! not once
Also
20 x 9 +38 235/35
20 x 10 +40 275/30
Also
20 x 10.5 et45 Rear
Tires
245/30-20 Front
285/25-20 Rear
I spoke with need for speed and they recommended the 245/30r20 front with 285/25r20 rear for my application being a 4matic.
I'd just been confirming the 10" rear. I also agree it seems crazy to run that low profile of a tire on a daily driven vehicle.
What part of Oz are you in? My girlfriend is in Melbourne for a couple months before she makes the permanent return.
I am a newbie here and need your advice...I found someone is selling 20" wheels and tires as a package and am wondering if the specs below will fit 2010 E350 fine.
It is what it is...please tell me if this will work or not work for my car.
• Bolt Pattern: 5 x 112mm (plus) +35mm off set
• 20" x 8.5" 225/35R20
• Tires are 9" wide x 26" tall.
Thanks in advance.
E
However, if you pair the 275/30 with the 235/35, you will have increased rolling diameter vs stock, but it will be even front to back. So it will still be pretty safe for the 4Matic. But the 285/25 & 245/30 combo will have you closest to stock rolling diameter and will provide the most accurate speedometer.
