Sponsored by: CARiD
stupid question about battery(ies) voltage
Old Aug 1, 2015 | 12:07 PM
mleskovar's Avatar
'17 Jaguar XF
Originally Posted by thefisch
...And from what I've read it's not a good idea to keep these batteries at a low % for the long term....
Correct. Low SOC promotes sulfation that reduces capacity and will ultimately kill a battery.
... Are you doing any supplemental charging with a trickle or other kind?
Yes. Every couple of weeks I trickle charge it overnight. It accepts a full charge and slowly goes down until the next recharge. I have my charge port easily accessible from outside the car without having to open the hood and the charger is permanently mounted in my garage so it's a 10 second operation.
Old Aug 1, 2015 | 12:46 PM
starbrite's Avatar
2004 E320
Originally Posted by Arrie
Would like to know what your statement of the need for "electronic testers that are programmed specifically for them" is based on. The link in your post does not work.
AGM battery still is a lead acid battery, it just is built differently but basic function of the battery is the same as traditional flooded lead acid battery.
I don't see any difference in load testing, i.e. you pull load from the battery and monitor voltage drop.
The link works fine for me Arrie. Here it is again :http://www.phillipsind.com/upload/re...1236015433.pdf
Just Google AGM batteries and you'll see the differences.
Old Aug 1, 2015 | 12:56 PM
thefisch's Avatar
Top Answer: 1
2011 E550 P2 4M Sedan
Where is the charge port you installed? I may do the same.
Old Aug 1, 2015 | 03:33 PM
Arrie's Avatar
Well, in your reference site it gives three options for the AGM battery load testing. The first one "Carbon pile" I think is the most used for all battery testing. The third one requiring the specifically programmed tester is the one done with "Handheld micro processor based tester".
The instructions further explain how to pull half of the CCA rating amps from the battery for 15 seconds and monitor the voltage. If voltage is at or higher than 9.6 volts the battery is good.
There is nothing special in this.
Old Aug 1, 2015 | 04:25 PM
starbrite's Avatar
2004 E320
I guess I put too much stock in the MB training manual. I'm no battery expert, so thanks for clarifying the info for me.
Old Aug 1, 2015 | 10:20 PM
Arrie's Avatar
Guess what, they are in business to sell you a battery too.
I let my dealer service to change the battery for me just to keep good relationship going while the car is still under warranty. It probably cost me $100 or so more than if I did it myself.
Next time I will change it myself and it does not have to be an AGM battery either. It probably will though.
Normal flooded lead acid battery will work in our cars just fine too. Just need to have it at the same or higher CCA.
Old Aug 1, 2015 | 11:15 PM
  #32
mleskovar's Avatar
'17 Jaguar XF
It's at the passenger end of the cowling outside. Close to the battery, easy to attach (don't even need to bend over), the hood line keeps away the air blast,water, and FOD, no extra anything required but I did zip tie it around the hood bracket just in case. I spliced some wires into the trickle charger (black&decker) plug, covered the splices and a good part of the wires with shrink tubing. I permanently mounted the charger in the garage above the spot and the cord just drops down to plug in. Multiple plug variations come with the chargers so you'll see which one you want to use. I'd stay away from the clamps though. I posted some pictures here somewhere. If you can't find them I'll take some more.
Old Aug 2, 2015 | 12:32 PM
  #33
thefisch's Avatar
Top Answer: 1
I searched for the pics and didn't see them. If you get a chance to point me in the right direction, that'd be great.
Old Aug 2, 2015 | 05:53 PM
  #34
mleskovar's Avatar
'17 Jaguar XF
I couldn't find them either The 1st one shows the trickle charger connected. For convenience mount it in the rafters if you have to and extend the cord. My cord lifts out of the way and is kept up when not in use. The 2nd one shows how it exits into the cowl from the battery. No hole added it just fits under a rubber seal. The 3rd shows how it snakes from the battery. The 4th shows it again in the cowl. The last is another view of the wires coming from the battery posts and going up.
You don't even notice the plug outside the car unless you know where to look and it's pretty protected from the elements. I knew if I didn't make the process easy I probably wouldn't do it as often.
Attached Thumbnails stupid question about battery(ies) voltage-dsc03619.jpg   stupid question about battery(ies) voltage-dsc03620.jpg   stupid question about battery(ies) voltage-dsc03622.jpg   stupid question about battery(ies) voltage-dsc03623.jpg   stupid question about battery(ies) voltage-dsc03624.jpg
Old Aug 2, 2015 | 10:08 PM
  #35
thefisch's Avatar
Top Answer: 1
thanks for the pics. I will look into doing this for charging convenience.
