2011 E550 downshifts even when in manual mode?
Then, as I hit the paddle to shift up (or wait for the car to redline and do it on it's own) the number STAYS at 4, and the RPM go back down to 2-3k again.
It appears to me the car is downshifting on it's own even when i'm in manual mode, but not changing the number from a 4 to a 3. Is this normal?
You can hold down the the downshift paddle and it will automatically drop you into the correct gear based on speed if you are looking to launch on an on ramp etc. Then right click away.
That's one of the main reasons I hadn't used my paddles much... this is my first automatic in 10 years so i'm used to just shifting from 6th to 3rd or whatever it is... pressing the paddles three times down/up was annoying to me but holding is way better!
The more I drive this car the more I realize MB has thought of everything
I would like to use the manual shifting way more than what I do but as I cannot hear the engine I end up revving the engine way higher than I like.
But I do use the shifter sometimes on 2-lane highways to pass where room can be limited. Holding that left side paddle for a couple seconds really sets the gear that gives you the best acceleration but you need to be quick hitting the right side not to red line it.
