Spark plugs question
Weistec M157 / M278 spark plugs are designed and manufactured for not only high power applications but also factory replacement. The factory iridium plugs do not handle the M157’s high cylinder pressures very well due to the very small electrode tip and frequently result in misfire problems, even on unmodified vehicles.
Our silver core BOSCH spark plugs can support significant increases in power while operating perfectly under normal driving situations. The M157 / M278 spark plugs are also 1 step colder to help prevent pre-ignition in engines that are making more power than stock allowing you to further push the envelope of your vehicle.
KEY FEATURES:
Higher Output for High Boost Applications
Colder range for better performance with increased horsepower levels
Direct replacement / bolt in for M157 / M278 engines
Silver core spark plug provides significantly improved performance over iridium
Suitable for all M157 / M278 vehicles from stock to highly modified
Set of 8
Over the years I have learned that NGK makes the best spark plugs for pretty much every possible application there is.
but imo, for a few dollars more id rather go for bosch. i believe theres no difference or not much, if theres any, if you stay with the correct specs between bosch and ngk, its probably just the brand name for me.
Bosch YR7MPP33 Original Equipment Fine Wire Platinum Spark Plug, GAP .032, this is also a Laser Platinum plug, 10.07 each-Amazon.
Denso IXUH22 Iridium Power Spark Plug, Gap .032, 8.99 Advance Auto Parts.
Homeofstone may know what the Laser Iridium Spark Plug part number is-I could not find it.
