Electronics go hay wire (occasionally)
The first time this happened, we had a tow truck come and take it to the dealer. When I picked it back up on they indicated the all diagnostics passed except the battery failed under a load test so they replaced it. I also learned at this point that it started right up for them on Friday.
The second time his happened, my wife left it in the garage. The engine did seem to be running rough the night before on the way home from the movies the night before. When I got home about 8 hours after my wife had this issue, I tried it and sure enough it went hay wire for me as well and this time I videoed it. It was later Friday at that point, so I figured I would deal with it Monday. I tried it again about midnight and it started up fine showing now issues except for an engine light. I pulled the engine code which was a P0500 Vehicle Sender Malfunction (I found two of them). They next day, I drove the car to the dealer and left it for them to deal with it (they were closed when I dropped it off).
The dealer of course didn’t have any trouble either and their diagnostics were clean. I did make them watch the video which I have on YouTube so they didn’t just blow me off. They performed SDS short test and found 30G codes (don't know that that means), no communication with tail lamps, ESM, SCM, A/C. They performed independent tests on SCM, ESM, tail lamps and all communications tested ok. The replaced the PRE-FUSE BOX and the erased all codes.
The questions I have for the members of this forum are as follows:
Was replacing the PRE-FUSE box a legitimate way to address the issue?
(Replacing the battery was obviously not)
Did they do that because it was a cheaper fix that is likely the problem and are hopping it goes away?
(We are less than a year and 10k miles from the end of the warranty)
YouTube video. If the link below doesn’t work search, “ETW”, “E350”, “Failure” and it should come up
This type of problem happens often on aircraft, and when they cannot be duplicated by the ground crew, you replace the 'most likely" bad actor and fly again. Includes massaging the wiring prior to changing the most likely bad actor. Somehow I don't think in the automotive world they do a lot of harness massaging while trying to duplicate the problem.
