Correct air pressure (tires)
Thanks for the help.
The Canuck cars do not have the TPMS system the states gets and we have to set the pressures manually and reset the monitoring system. If a tire goes down the diameter changes and the wheel speed sensors of the ABS tell the system of a soft tire.
On the American systems the pressure sensors in the wheel itself read the pressures.
Assuming you have set things up in the system before setting the pressures and given that putting the rears up to 48 shuts off the caution and the front remains I suspect you have a system problem where the signals are not getting translated correctly.
Set the pressures manually to the gas door settings per the loadings until you can get the system checked at a dealer.
i think its page 233
