Is this HID or regular halogen?
I thought H7 refers to the size. So, regardless of whether he had a halogen or HID bulb that went out, he would want to shop for an H7 bulb.
TS, what I believe you need to look for when you shop for the replacement light is make sure you get a low beam and make sure you get either halogen or HID to match your other lights.
As the previous poster pointed out though, now might be a good time to consider changing both the low/high beams to HID because the kit only costs around $140 plus installation. By purchasing a kit you also get to select what color light you like best.
http://www.vindecoderz.com/EN/Mercedes-Benz
Also in terms of color temperature, only the 4300k ones are considered street legal if you also have the xenon projectors, otherwise all other colors do not meet DOT approval and the local police can ticket you if it's obviously not a street legal color. Also the kits are probably not street legal unless you also change out the projectors.
OP, if you're confused as to what type of bulb you need, you can always pull out your stock bulb and post a pic of it or email to us at aznoptics@gmail.com and we can identify the bulb for you so you know what you'll need.
You'll need regular halogen H7 bulbs.
