Sponsored by: CARiD
Resetting Check Engine Light
Old Jan 17, 2016 | 12:19 AM
crackerjack's Avatar
I know the code so, is there a procedure I can use reset the Check Engine Light without a OBD II reader?
Old Jan 17, 2016 | 08:50 AM
aquinob's Avatar
2010 E350, Sold 1998 C230
It may reset itself (at least turn the light off) after so many starts without the initial problem present but the code will still be in the memory. No other way I know to clear the code without a reader. They are cheap enough, can be had in the 20 dollar range from just about anywhere or you can borrow one from an autoparts store. Nowadays, they are a necessary tool to have in your kit. Just go buy one.
