'11 E550 4Matic sedan front wheel spacers?
First, yes i have searched. Looking for info on running a wheel spacer on a 2011 E550 $matic sedan. I want to run 12-15mm. I bought some 12mm ones that would work on the rear but not the front, the step hubcentric ring interferes with the long snout. Has anyone run larger than a 5mm spacer up front?
For front you need H&R p/n 24556659 (12mm spacers) or p/n 30556659 (15mm spacers).
https://www.ecstuning.com/Search/Sit...659/ES1831838/
JT550 (03-31-2016)
Also, does anyone know the length of the threaded portion of the stock lug bolts? are they tapered or round? (haven't had mine off for a while and can't recall)
Cheers
threeMBs or fellow forum members, I need your infinite wisdom. Is it possible to run a 10mm front and 5mm rear on one of these? (4matic). I recall at one point reading there was a minimum thickness needed to run in order to retain adequate support....
Cheers
Cheers
Stock W212 bolts are MB ball(round) seat (R14) with just under 28mm thread length.
Abrown3mtg (04-01-2016)
2013 E550 4Matic
Cheers
Cheers
