Sponsored by: CARiD
Help! M278 oil filter??
Old May 4, 2016 | 01:29 AM
mjec515's Avatar
2014 e550 4matic
First time changing the oil on my "14 e550...when I removed the oil filter it came out with the cap....the new one I installed into the cap then tightened it down into the housing...I just wanna make sure I'm doing it right...
Am I supposed to install the oil filter into the stem first? Or installing it into the cap then tightening it down is ok?
Thanks guys!
Old May 4, 2016 | 07:49 AM
threeMBs's Avatar
Only MBs - the best or nothing
Thanks guys!
Filter must be installed into the cap first - there are clips on filter's closed end that must engage into recess area on bottom/inside of the cap. Once its engaged, its safe to install on stem and tighten down.
