w212 battery drain 2011 e350 bluetec
2011 e350 bluetec
battery draining started in august. dealer indicated a faulty starter then but that did not help. then came a new battery followed by a new alternator in the fall. better over winter, but now car does not turn over at all. any ideas? 49,000 miles
Received 4,417 Likes
'71 Pinto
Request dealer revisit/repair at cost referencing following bulletins.
- LI54.10-P-051559 Check cause of battery discharge.
- LI54.10-P-051681 Battery discharge with KEYLESS Go (889) if so equipped.
- LI54.10-P-054089 Battery discharge rotary light switch may send wrong signal after ignition off, replace switch.
IIRC folks with early model W212 complained about battery drain and it was linked to the climate fan running after shutdown to dry evaporator. Perhaps it runs too long and wears down battery. Solution was to program car to not run fan later on. Maybe that is one of the bulletins that konigstiger posted, but I can't tell.
'71 Pinto
LI20.40-P-053718
