Sponsored by: CARiD
Flickering reverse camera screen?
Old Jul 8, 2016 | 03:33 PM
Zavato's Avatar
2012 E350
Anyone ever experience a reverse screen that flickers? Recently experienced that- normal radio, phone and Nav display is rock solid.
Software or hardware issue? Thanks-
Old Jul 8, 2016 | 03:36 PM
thefisch's Avatar
Top Answer: 1
2011 E550 P2 4M Sedan
https://mbworld.org/forums/e-class-w...era-issue.html
https://mbworld.org/forums/e-class-w...t-working.html
It happens from time to time for folks. Hasn't happened to me in a while. How often is it happening to you?
IIRC someone posted about a loose cable in the trunk lid that helped them out. I don't recall if their issue was flickering.
Old Jul 8, 2016 | 04:41 PM
PaulE550's Avatar
2015 E550 Coupe
Screen flickering is typically a hardware problem. Intermittent or loose electrical connection. I would agree with thefisch that it is likely on the rear camera end, as the cable runs through the trunk lid and the cable is flexed repeatedly over time, as opposed to be a connection into the Command unit that never moves..
Old Apr 29, 2020 | 01:26 PM
Kashan Gulfraz's Avatar
Mercedes E250 W212
E250 W212
I have the same flickering problem. I have changed everything. Camera, long cable, power cable, fakra cable. Still it is flickering so i think the problem is in the Comand
