Help please need to get back on the road
Now yours was fine before the belt broke but the system now thinks there could be an issue whether that is true or not. That could be from the compressor stopping due to the belt breaking and a sensor got tripped and cannot reset without intervention or it went bad. Or it could be that the r134a refrigerant in the AC system could have vented out due to pressure buildup due to the interruption in the cooling cycle and it is now low on refrigerant.
I am suggesting getting the level checked as that is easy to do - most auto parts store can help or sell you a refill kit that comes with a pressure guage. if it is low then an AC tech can help you get it recharged if you don't want to do yourself and then you could be good to go. If the level is fine, then you can explore other reasons why the light may be flashing like a bad sensor.
btw key08 I work for a private company called UgO very similar to Uber. lot of private companies, corporations politicians, etc book you in advance mostly you will get there monthly itinerary.
It is concerning that your gauge reading is in the red regardless but it makes me wonder if something is wrong with the gauge. Do you have another car to test it on? If my gauge was good and showed my system in the red, I would be getting it checked out by an indy or dealer. Of course any reputable AC place can help. You can always ask them to diagnose the situation if they charge a nominal fee. You've got to get back on the road to get paid
