Sponsored by: CARiD
Flat spots on wheels?
Old Sep 19, 2016 | 11:09 PM
iGeorge's Avatar
'12 E550 4M, '14 ML5504M
I have the 18" alloy wheels for my 2012 e550 4m; Mercedes part number 212 401 3602 88. This past week my mechanic showed me a flat spot on the wheel between the spokes; he says they aren't bad enough to damage the ride, and it didn't affect the balance, so I shouldn't panic. But I'd like to ask some questions:
In the forum members experience, are these flat spots common?
In the forum members experience, are these wheel tolerant of the presses used by rim repair companies.
Should I consider repairing or replacing the wheel which has the flat spot?
Old Sep 19, 2016 | 11:26 PM
Sunnyslope48's Avatar
2016 E350 Sport 2WD
Is the flat spot on the mounting surface of the tire? And how big is this flat spot? Can you post a picture of this? If it isn't on the mounting surface and you have no balance problems, I wouldn't worry about it. Of course, if you are one of those that just needs things to be perfect, by all means repair or replace it.
Old Sep 20, 2016 | 02:47 AM
belarus27's Avatar
2010 e550 p2
never even heard of this before.. what is a flat spot? can anyone enlighten me plz
Old Sep 20, 2016 | 04:10 AM
Uda880's Avatar
2010 E550 Coupe
I think the only times I've ever heard flat spots being talked about was when members park their cars for prolonged periods of time, and the tires begin to deform and create a noted indentation on the contact patch with the road/garage surface. It usually evens out after some driving.
Old Sep 20, 2016 | 07:58 AM
RA72825's Avatar
This flat spot is on the wheel? Never heard of this, ever.
Old Sep 20, 2016 | 09:37 AM
belarus27's Avatar
2010 e550 p2
thank you..... i wonder how long it has to be park in case for it to happen.... years? lol
Old Sep 20, 2016 | 11:00 AM
Uda880's Avatar
2010 E550 Coupe
Some times even months, or weeks. Good example is if we parked our cars when the temperatures change and tire pressure lowers, all while entirely parked due to some business or life circumstance, when the car is driven again, the ride will feel uneven and bumpy for the first few miles.
Although in the OP's case, I actually think this may be an actual manufacturing problem on one of the wheels? But if it's balancing out and not losing air pressure, I wouldn't worry about it.
Old Sep 20, 2016 | 11:38 AM
Trelos's Avatar
2012 E350 4MATIC
OP, By flat spots do you mean bent rims?
Old Sep 20, 2016 | 12:03 PM
RA72825's Avatar
Bent rims are usually on the back side of the wheel in the barrel where it's weakest. Not the face typically.
Old Sep 20, 2016 | 02:18 PM
cetialpha5's Avatar
I've had my rims fixed before. The guy says that OE rims are easy to bend back and they are fine afterwards, aftermarket ones are sometimes weaker and don't hold up as well. The flat spot is probably from hitting a pothole or curb. And if you see it on the outside, you should check the inside, probably there too.
Old Sep 20, 2016 | 02:49 PM
thenew3's Avatar
2020 X7 xDrive40i, 2016 X3 sDrive28i
Flat spot on tires can happen overnight. Depending on the compound and design of the tire.
If I don't drive my car for 2 to 3 days, I will get slight vibration in front end for the first couple of miles due to flat spotting in the tire.
Flat spotting in the wheel is usually a manufacturing defect or you hit something hard enough to cause the wheel to bend.
It happened to me once when I hit a 2x4 piece of wood on the highway (fell off a truck in front of me and I didn't have enough time to dodge it).
It bent the rim and caused a "flat" looking spot in it and could be felt in the steering wheel as severe vibrations. Tire was not damaged, so I had to have the rim replaced.
Old Sep 20, 2016 | 04:35 PM
belarus27's Avatar
2010 e550 p2
at first i thought it was something similar to this , but i guess its a different thing
Old Sep 20, 2016 | 04:49 PM
thenew3's Avatar
That looks like you hit something, there's some paint scrapped off on the edge of the rim as well.
That looks like it should be fixed or replaced ASAP.
Old Sep 20, 2016 | 05:21 PM
belarus27's Avatar
2010 e550 p2
NO NO , its just a pic from the internet , i thought thats what *flat spot* look like... i was wrong.
(i had bent wheels like that in the past tho)
Old Sep 20, 2016 | 05:22 PM
thenew3's Avatar
Ok that looks similar to what happened to my wheel after I ran over that 2x4 at 80mph.
The tire didn't blow out or leak but was getting violent shakes in the front end.
Old Sep 20, 2016 | 10:47 PM
iGeorge's Avatar
I can't show the flat spot unfortunately; the tires were being replaced and before the car came off the lift, the mechanic spun the wheels to show me the flat spot while watching the edge of the rim spin by.
Old Sep 20, 2016 | 10:51 PM
iGeorge's Avatar
Yes, bent rim, seen from the inside aspect of the rim while I was standing under the car; the car was up on a lift.
Old Sep 20, 2016 | 10:53 PM
iGeorge's Avatar
It not nearly as bad as that photo, but yes, the same type of thing. Wow, I guess this isn't an uncommon occurrence! Thank you all so much for the replies! I'll look to see about repairing the rim.
Old Sep 20, 2016 | 11:16 PM
belarus27's Avatar
2010 e550 p2
whete you located , i could hook you up with a wheel repair guy , would cost you only 80 bucks.
Old Sep 21, 2016 | 07:32 AM
iGeorge's Avatar
PM sent, thanks!
Old Sep 29, 2016 | 07:58 PM
cx876's Avatar
W212, R171
can you send me the info too ?
I'm in SF and I believe two of my rims are bent slightly
Old Sep 30, 2016 | 10:20 AM
belarus27's Avatar
2010 e550 p2
PM SENT
Old Oct 12, 2016 | 11:04 PM
MBNUT1's Avatar
2010 E350 4Matic
In the morning on my way to work I get what could best be described as a beat frequency resonance It seems to improve as I drive more. Did your tire flat spotting make a similar vibration?
Old Oct 13, 2016 | 09:56 AM
thenew3's Avatar
Sounds about right. If it goes away after a few miles (when tires warm up) then it's most likely flat spotting in the tire.
