Sponsored by: CARiD
W212 - 3 cigarette/aux ports do not work but 1 does?
Old Sep 20, 2016 | 08:30 PM
Benza_nomics's Avatar
2011 E350 4matic
Hey guys, I need your helps on something odd.
on my 2011 e350 4matic, the fron cigarette lighter (next to ashtray) does not work; as well as the one in the glove box. There is one in the Trunk on the righ side that has failed as well. The only one that works is located in the center console by the rear seats. I have checked ALL fuses one by one with a tester with my ignition on. I opened up the previous Accessory charger (Cig lighter to usb ports) and discovered it was burnt internally. How could all 3 Cig ports fail at once without being a fuse?
Old Sep 22, 2016 | 08:21 AM
Youngd's Avatar
2011 E-350
Not sure, but I wouldn't be surprised if there was a separate in line fuse for the cigarette lighter. Have you traced the wiring in the console?
Old Sep 22, 2016 | 02:30 PM
belarus27's Avatar
2010 e550 p2
my friend has a bmw f10 , both of his cigarette lighters didnt work , he checked fuses and found the one for it was blown....
so check fuses. easy stuff. 99.9%
Old Sep 22, 2016 | 06:52 PM
davidjohnbamber's Avatar
2013 E550 Sedan
Fuse boxes
Fuse boxes are in the right side of the trunk, and engine compartment. Did you check both? Also there is a fuse chart in the tool kit under the trunk floor.
