Sponsored by: CARiD
Vibration or shuttering while driving
Old Oct 27, 2016 | 09:35 PM
Teamsabino's Avatar
Current: W222 2020 S560, W212 2016 E350 Wagon. Previously: W212 2010 E350 Sedan
Unhappy Vibration or shuttering while driving
Hoping someone can help. Past month or so, I've been getting vibration while driving between 1700 - 2200 rpm, at any speed. It's most noticeable when climbing slight hills. Happens with me controlling the throttle or on cruise control. No check engine light. Nothing while in neutral or park. Fine under hard acceleration. Dealer can't find anything wrong.
I've looked through the forums, and haven't found anything.
Any ideas or questions that might help?
Old Oct 27, 2016 | 11:46 PM
cocobeex's Avatar
2014 E550 4MATIC TUNED - Turbo Upgraded Stage 3
Engine mount issue ?
Old Oct 30, 2016 | 04:04 PM
Teamsabino's Avatar
How owe can I check that?
Old Oct 30, 2016 | 04:38 PM
PeterUbers's Avatar
no idea but try an alternate dealer
seems engine or drivetrain related, intakes ok?
transmission mount also to be considered ...
Old Nov 1, 2016 | 03:44 AM
Abrown3mtg's Avatar
2010 E550 4Matic Sport P2
Is the vibration the same regardless of speed or does it increase/decrease with speed as well? (Does it seem rotational)?
How many miles are on the car? How are you sensing the vibrations? (steering wheel, overall), car feels like it is losing power, sound, etc).
Old Nov 2, 2016 | 06:40 AM
designzio's Avatar
21 E63 Wagon
Could be driveline related. Especially since you mentioned it occurs while under a load. Can you feel it near the front or rear of car?
Old Nov 2, 2016 | 02:33 PM
Wolfman36's Avatar
2014 Mercedes E63 AMG S
This happened to me w/ another car & it had something to do w/ the car's computer chip. They had to re-calibrate it or reprogram it or something like that; but whatever they did, it ended up working. Not saying this is your problem, but may be possible?
Old Nov 3, 2016 | 07:23 PM
Teamsabino's Avatar
I definitely feel it more in the front (steering wheel, pedals, seat).
Old Nov 3, 2016 | 07:25 PM
Teamsabino's Avatar
I just tipped 100k. Its not speed dependent. I will feel it around 40, 50, 60. But as soon as I feel it, I can stop it immediately by letting off the accelerator (or flooring it).
There may be a low sound when it's occurring, but nothing really noticeable.
I can repeat it fairly consistently at those low RPM (1700-2200), especially while climbing a hill.
Old Nov 3, 2016 | 07:35 PM
designzio's Avatar
21 E63 Wagon
Sounds more and more like a drive line issue
Old Nov 3, 2016 | 07:37 PM
homeofstone's Avatar
2011 E63, 2011 Hyundai Genesis 4.6 v8, 2013 GMC Denali XL, 1965 Ford Mustang, 2005 Merc. E500
Driveshaft flex joints may need replacing.
Old Nov 4, 2016 | 07:39 AM
MercFiveHundred's Avatar
2014 E550; 2003 E500
Check for codes via STAR. My e500 did the exact same at the same mileage. Conductor plate needed changing. STAR confirmed speed sensors in conductor plate were bad.
Old Nov 4, 2016 | 08:52 AM
sprfrkr's Avatar
E350, W140 S, C63, G55, 420SEL, Prius, Dune Buggy, Ducati
^ This is my thought as well
Old Nov 15, 2016 | 12:57 PM
RDNXXX's Avatar
2000 ML320
I have the same issue on my w220 2006 S 500. In the dealer shop right now for Transmission fluid change and screen change out. they are only guessing though
so the question i have is what are conductor plates, where are they, and what might be a cost to replace.
Old Nov 20, 2016 | 04:43 PM
sdenn's Avatar
2014 E350 4Matic
I have this issue, have posted on this before. Dealer has attempted to fix 9 times so far. MB corporate has been involved, they have extended the warranty to 7 years 70k. Next step will likely be a torque converter or new transmission.
It is very intermittent, very frustrating.
Old Nov 22, 2016 | 09:36 PM
Teamsabino's Avatar
Finally got a test ride with the service foreman. He knew practically instantly that it was the torque converter and solenoid. Unrelated, he also recommends I have my transmission and motor mounts replaced. All covered under warranty, thankfully. Setup my appointment for next week.
