2010 E class -- rear tailight issue
kind of have a weird issue. dont know where to start to trouble shoot...
on the dash screen it says to check my left rear tail lamp. When i turn my blinkers on -- it does not light up the blinker bar. instead it will blink the top and bottom brake lights. i assume this is for safety reasons -- better to have a blinker than not!
my issue is that when i click my alarm -- the blinker lights actually will go off and on. even when i start my car it the rear blinker will work correctly. its only maybe when i drive about a minute that the rear left blinker will stop working and it will then throw the " check rear left tail lamp"
when i unplug the left rear lamp from power and then plug it back it... it seems to work ok for a while... then it throws the errors again. i see no LEDS that are burnt out on within the Blinker section...
brake lights are perfect...
do you think it could be a simple fuse fix? any one else have this issue?
might a take the tail light out , and check all of the bulbs in there , pretty sure this is it.
when i click the alarm button all of the turn signal LEDs light up ... its when i turn the car on it will throw the check the rear lights...
again -- all brake lights work
--- when singaling left -- turn signal will work then error out -- then both top and bottom brake lights signal =(
