Anyone have a 2012-current E550 w/the latest Renntech tune?
I would like to point something out about this new tune as compared to the old and how it will affect quarter mile results. First thank you to TonyCPA for taking the time and money to have his car dynoed and provide us with this information. Now if you look at his dynoes all the new power/TQ seems to be below 4500rpms. Unfortunately, when we run our cars at the track once out of first gear, we are only above 4500rpms throughout 2nd and 3rd. This can be seen here in this video:
Now, while this torque is "there" for 1st gear anyone with this car will know that the launch on these cars is what kills them at the track. MB has limited the torque in 1st gear, same issue we are seeing on the e63's. While he did gain a few peak HP (which is great), 10-15hp on a 500hp car may not yield the results we are hoping. Iam curious what Tonycpa will run if he took his car to the track again, but wouldn't be surprised if the times and ET were very similar to his previous best because of what I have just noted.
Tony, there is no doubt we have 11 sec cars...we just need to be able to launch them to get there. Your 115mph trap is good for a mid-high 11 easily with a decent launch. 1.9X 60ft is horrible for a 600hp AWD car, and its no fault of yours, its MB with their torque management. My friends have AMG's that trap around 117-120. When we run on the highway, I'm right there with them. This cars are very fast for non-AMGs..but unfortunately (or fortunately) its more evident from a roll.
I am by no means knocking renntech or the products they produce. I would probably get this tune had I not had one already. I just wanted to point out some things that others may not have noticed.
The following 2 users liked this post by Juice1979:
J.M.G. (11-30-2016),
mercshepherd (04-25-2019)
if tonycpa hits 11's i will definately get my m278 hooked up
i was never really satisfied enough to do mods because they were still in the low 12's i want 11's..even 11.99999
i wish we had LAUNCH CONTROL- this thing would easily run 11's
e63AMGjoe's CLS550 went 12.22 with just tune and filter i believe
tonycpa- do you have the intercooler pump upgrade on yours?
2014 E550 4MATIC TUNED - Turbo Upgraded Stage 3
https://mbworld.org/forums/cls-coupe...50-4matic.html
this is the guy on stock M157 turbo with m278 engine and custom tuned.
2013 E550 4Matic
Roads "in Mexico" are dry this morning... there's a spot where the highway opens up to 3 lanes, which is about 1/4 mile from an overpass. Usually if I'm cruising at 70 by the lane split and floor it, I'll hit about 130 rabbit hops by the time I pass under the bridge. This morning I got up to 145 rabbit hops. I didn't time it this time.
Also, even with ESP off, I couldn't get a good launch from a stop (probably need to work on technique). But I think a lot of it has to do with the torque limitation in first gear. This doesn't bother me, since I do most of my passing at speed anyway, and it does that very well now. On the other hand, I didn't get any wheel hop from that launch... but once it shifts to second gear, sayonara.
J.M.G. (12-01-2016)
#32
Ok so can you say you are 100% satisfied? I only ask because I'm local to OE Tuning, Weistec, World motorsports and RB tech all here in southern california. No one is claiming 700+ftlb of torque so I'm so on the fence of what tune to go with. I have access to two dynos and damnit I wish some of the guys that are tuned here in so cal would be down for a dyno day so we can see what kind of power these cars are making. When I talked to Renntech they were telling me that people with their new 550 tune were dynoing quite a bit higher than advertised.
http://oetuning.com/blog/stage-2-cls...uning-results/
and they are local to you.
#33
2013 E550 4Matic
I can honestly say I'm about 90% satisfied. Over the past week of driving it, I've noticed a couple things:
- You need to turn off ESP to get the most acceleration out of it (duh) but, even then, my ContiProContact all-seasons still slip. Will be fixed in the spring when I put my summer wheels back on. A buddy was following me in his Golf R and noticed my tires slipping a little extra (even though no ESP lights were flashing, so it must've been slight enough not to trigger the sensors). This doesn't affect my satisfaction because I know the cause and solution; the next one is what keeps me from 100% satisfaction...
- At about 50-75% throttle with slow "lazy-but-spirited" application, the turbos cut out... it doesn't flash any lights or anything, but it jolts as the torque cuts out and it doesn't feel good (to me). I've only been able to replicate it with those conditions, and it doesn't happen every time. But 50-75% throttle with fast application, <50% throttle with all applications, and WOT all operate as normal/expected. It's just that slow 50-75% throttle (e.g. passing on the highway or accelerating from a light) where the turbos cut out. It does it in both E and S mode. I'm going to email Renntech about this this morning to see what that might be about. I'd be curious if Tonycpa has this issue as well.
- Despite that, even in the wet (it's soggy this morning), the tires still hook up (eventually) and that ~4s pull to 60 puts a smile on my face lol
If you're local to OE Tuning, just go with them. If you have any similar issues like this, you can just take it to them and sort it out in person.
#34
#36
2013 E550 4Matic
It seems to me that your vehicle might be creating way too much boost and as a result sending you car into sort of a limp mode, closing the valves on your turbos. I believe that is why your are not getting any problems at lower RPMs. Maybe get a boost gauge and see just exactly what are your outputs.
It reminds me of when I waterlogged the intake on my Civic back in the day and it wouldn't let me rev over 3500RPM to protect the engine... but then again that car took forever to gain power, and made it at higher RPMs, and I think the E makes more power in one cylinder than in the Civic's whole engine lol
^ this actually gets me thinking of another possibility that the engine isn't getting enough air. I'll have to go make sure my intake ducts are set correctly, because the ones I had disintegrated when I was changing filters and I had to make makeshift tubes from Autozone (which don't stay put very well) until I could order new OEM ones, which I now have and just haven't installed... I meant to, though. If this is my issue, then
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
#37
Great thread, helps me assure myself of the e550 purchase decision in the next couple of months.
I have a question for you guys that are tuned. Are any of you running downpipes + exhaust mods along with the tunes? Or these are just straight tunes and resonator deletes?
I would be curious to know the how the downpipes would play in with the tunes?
#39
I think it's a fuel cut (limp mode, as you say), and it happens at about 2000, 3000, and 4000 RPM in any gear at 50-75% throttle, then once it gets to #100 RPM it resumes as normal. If it's too much boost, then I would think it would peak around the same RPM in each gear without that much variance, and then stay in limp mode and not go up in RPM. I sent another email to Renntech to see what they say.
But I don't think it's the whole problem, because more speed = more air, and it handles higher speeds just fine.
Good luck, love the w212 550.
#40
Do you happen to have any videos of your setup?
#41
Are you planning to do down-pipes in the future? I am curious to see how much louder the down-pipes will make the exhaust sound with resonator delete + mufflers. Cant find any videos on youtube with a FBO 2012-14 e550. I am curious to see if it sounds anything like the E63s.
Here is the video of my car a year ago.
The car was Catless downpiped, muffler deleted.
It is super loud...way louder than stock E63.
Sounds like truck....
#42
2013 E550 4Matic
Edit: Other solution would be WOT... everywhere... LOL
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
https://youtu.be/c4rSIUfZrYU
https://youtu.be/CPRibMZrx7E
#43
Only the second resonator were still on.
It was way too loud and raspy when driving.
It gave backfire popping sound when downshift (Loud popping). I wonder if car from behind can see the flame burst out from the exhaust...lol
High speed WOT, it sounds like F1, high pitch sound...its so awesome
Down sides are.....
It drew attention to cops couple times.
I couldn't drive this car out at late night. Cold start would woke everyone up.
its very emberrasing in the neighbour hood.
And...It droned like crazy when my family went on a long road trip.
Few month ago, I replaced 2nd resonator with X-Pipe and installed Magnaflow mufflers.
Now, it is real music to my ears and wife is happy.....lol
#46
Haven't have time to film the video after installed xpipe and muffler.
Its more of refined sound, but almost no popping (backfire) sound now.
At lease, it won't draw too much attention to cops and hateful eye contact from neighbors.
I will find time to film it later.
#47
Hey Coco i just signed you up for this, 1st place gets decent hunk of doe, and ill cover your entry fee ![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
https://www.youtube.com/watch?v=_18V58mHYfw
Now, the sound is a lot more refined.
#48
2013 E550 4Matic
I'm wondering if just replacing the cats with high-flow cats will do what I need... I like the tone I have now, just wish it was a little louder.
RE: the main topic here, I think the problem I described above is also partly due to ESC being on... driving with it off makes the fuel cut happen less, but it still dips a little at certain RPMs. But turning off ESC means I can't use cruise control, which inhibits the "keeping the stock daily driveability" they claim, so I will keep pushing to see what they suggest we do about it. Don't remember if I mentioned this before but, with ESC off, the WOT pulls are a lot more fun
#49
#50
RE: the main topic here, I think the problem I described above is also partly due to ESC being on... driving with it off makes the fuel cut happen less, but it still dips a little at certain RPMs. But turning off ESC means I can't use cruise control, which inhibits the "keeping the stock daily driveability" they claim, so I will keep pushing to see what they suggest we do about it. Don't remember if I mentioned this before but, with ESC off, the WOT pulls are a lot more fun ![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
In any case, "a fast Mercedes that almost works most of time" just does not sound good, it sounds ghetto to me.
