Sponsored by: CARiD
Replacing an Idler pulley on 09 E350
Old Dec 18, 2016 | 11:36 AM
Winterhorse's Avatar
2008 E550
I'm replacing the upper idler pulley on my '09 E350. The new part came with a new bolt and washer. The bolt has a rubber washer on it that sandwiches the steel washer between head of the bolt and the rubber washer. Should I remove this or install it as part of the assembly?
Old Dec 18, 2016 | 01:39 PM
konigstiger's Avatar
'71 Pinto
See attachment. BTW you should be posting here https://mbworld.org/forums/e-class-w211-20/
File Type: pdf
