2010 E350 Hockey Running lights - HELP
Help? Don't want to check the light with 12 volt only to blow it? $125 replacement. Light wasn't damaged unless something broke when wires were yanked out?
I had to change my passenger side hockey stick light as it just burned out. I was also worried when trying to check for the voltage on the disconnected socket. Turned out that the thing worked fine with the new replacement light.
Somehow in my car there is no voltage coming to the wires if they are disconnected.
