2010 E550 4Matic - slight delay on engine crank when turn key to start
About a month ago, it started having a slight issue when I turn the key to start it cold. Starter turns over once, pauses a half-second, then turns again and the engine fires up just fine.
Not sure if it is battery, starter, or other. Does the 2010 E550 4Matic flash a warning on the dashboard if the primary battery is dying? I plan to take this to an MB mechanic but wanted to check with you guys first.
Location is St. Pete, FL, where it doesn't get too cold. Lows the past month have been 55 degrees F. No other issues with the vehicle, and it has started/run perfectly fine before this.
there are threads about this exactly the same issue , id ppst a link but itll take some time to find them on the phone. So just search for it. Good luck
