Is my 4MATIC Working?
We got hit with about 15-18 inches of snow. I was reversing out of my parking spot and my wife said only my rear wheels were spinning not the front wheels. My wheels were slipping on icy snow and the yellow traction triangle was coming on. I did finally get the car out with more acceleration. My wife said she forgot to check if my front wheels started to spin when I finally pulled out. I did get out of the spot though. I had to push her Nissan out.
So my question is, is my 4MATIC working? Are all 4 wheels always supposed to spin simultaneously?
Anyone see an issue??
Received 1,616 Likes
2014 E550-sold 😩
Turn off your traction control and mash the pedal on snow.
2014 E550-sold 😩
I am simply providing an answer to your desire to see all 4 wheels spinning. Not sure what your question is.
Have you considered that the rear wheels have compacted the snow so that your front tires don't have to be going at the same speed while you are in reverse?
01 ML55AMG 04 ML500 03 ML350 08 ML63AMG
What he ment was, when you shut off your traction control, you will notice the difference. Plus if its really icy or slippery you can have 6matic lol you still going to spin tires.
I check mine 4matic this way, on the turn when car starts sliding i mash the gas pedal and it straights itself out, that means ur 4matic is good. try that, but im sure ur car is fine.
Received 1,467 Likes
I forget the exact split, but it's more like 60 to the rears and 40 to the front. If they all spun that would mean you had no traction which probably means you were mashing the gas pedal. That's why the car still fishtails if you nail on a slippery corner. If you didn't have 4matic, you probably would have been stuck, the rear wheels would spin and the front would do nothing. There's no issue.
Learn something new everyday - will play with traction control the next time.
That's difference between 4WD and AWD, if it was 4WD, all the wheels will spin at the same speed.
2010 E550 P2 w/AMG Sport Package + Pano, 2015 Nissan Pathfinder
The magical spinning wheels are always in effect on my RWD lol. Even on a rainy day if I don't take it easy it's like a Dukes of Hazzard re-run.
I forget how to turn off the traction control. Is it through the engineering menu?
2014 E550-sold 😩
No, it's a button on the dash. Do you have a manual?
I have a manual saved on one of my computers at home. I haven't pulled it up in awhile. I really doubt I'll be turning off the traction control but just more so a FYI if someone knew it off the top.
2014 E550-sold 😩
Yep, it is designed to be easy to turn it off when you want to. Fair warning though, it is also designed to not be "completely" turned off. To do that you do need to go into the engineering menu, especially if your car is going onto a dyno.
jahquan3 (02-13-2017)
The 4Matic of the C, E, S, CL, CLS, and GLK models has a mechanical core that splits the torque at a ratio of 45% front and 55% rear. It works through a multi-plate lock in the center differential, which has a base locking force of 37 lb-ft (50 Nm).
Mercedes-Benz claims the system can deliver a load distribution of 30/70 in either direction, depending on ESP, 4ETS, and ASR electronic control systems and the challenges of the road surface. The electronic systems are adjusted to let the all-wheel drive do the corrections first, and then intervene to control the situation if required.
It sounds like in that situation the center plate thought there was more traction to be had in the rear wheels. These awd systems can make odd decisions during starting or stuck situations. it doesn't sound like the front tires had enough momentum to move the car even if they were getting some of the engine torque which they should have unless the passive tcs was applying the brakes. I usually turn off the basic ESP during winter conditions as it seems to easy to over throttle and confuse it.
2014 E550-sold 😩
In heavier snows I always turn off ESP as well and find that traction and drivability improve at normal urban speeds around town.
2013 E550 4Matic
Same here... ESP is off in the snow and have had much fewer "close calls" since. The electronics are smart, but not that smart. Nothing wrong with a little oversteer in the snow
2014 E550-sold 😩
Exactly, easy to control and ABS is always working to get you stopped properly. Turning in front of oncoming traffic in snow is always a hoot when the ESP decides to give you that long pregnant pause. LOL
I think your center differential lock is worn out as it obviously does not have enough traction to give front wheels power to move the car when rear wheels are on slippery surface.
