Sponsored by: CARiD
Clearance with 20s on e550 ?
Old Feb 27, 2017 | 03:00 PM
Tonyb203's Avatar
2010 mercedes benz e550
I want to put 20s on my 2010 e550 with airmatic. Any idea if there will be a clearance issue?
Old Feb 27, 2017 | 04:10 PM
blegthbloo's Avatar
2013 E550 4Matic
Depends on offsets and tire size... what are you thinking?
Old Feb 27, 2017 | 04:34 PM
belarus27's Avatar
2010 e550 p2
There are so many threads about this lol
it is easier to post a new one i guess... no im not hating lol its just a funny observation.
but yes.. depends on a lot of things , more info would be useful
Old Feb 27, 2017 | 05:14 PM
Tonyb203's Avatar
I want to just buy and put on. No spacers. None of that stuff just on and off for summer. But I don't want to buy something and have it rub
Old Feb 28, 2017 | 07:59 AM
blegthbloo's Avatar
2013 E550 4Matic
Get my setup in my signature block... you'll be fine. That's about the limit of what we can fit on our cars without issues.
Old Feb 28, 2017 | 05:00 PM
Abrown3mtg's Avatar
2010 E550 4Matic Sport P2
Is your car a 4matic or rear wheel drive?
Tonyb203's Avatar
4matic
Old Feb 28, 2017 | 06:46 PM
Abrown3mtg's Avatar
Where do you live? Tire selection/size will play a role if you need winter performance.
Old Feb 28, 2017 | 06:50 PM
Tonyb203's Avatar
Il put my stock wheels back on for the winter I want summer wheels. Easy on easy off
Old Feb 28, 2017 | 09:49 PM
Abrown3mtg's Avatar
Oh. I thought you meant you wanted you didn't want to switch sets from summer to winter.
Your question is really really vague which is why I don't think you're getting much feedback here. Perhaps post up a few options of wheels you like and people can make suggestions if they will work. In a 20x9 front plan a 32+ offset and rear 20x10 or 20x10.5 with a 42+
Old Feb 28, 2017 | 11:30 PM
Tonyb203's Avatar
Ok good point. I'm new to the forum. So I don't know much yet
Old Mar 1, 2017 | 04:22 AM
Abrown3mtg's Avatar
I totally get it. There are a million options. Generally the most aggressive will be a 32 front and 42 rear (20x9 and 20x10.5). Lower numbers mean wheels stick out more, higher numbers less. Each tire also runs a different true width/height. Cocobex runs 20's all year with a 245/30r20 front and 275/30r20 rear DWS from conti and is ok.... technically for the health of the center differential you want to run 245/20r20 and 285/25r20. These offer less rim protection and now real winter option...
There are loads of threads on options but it's hard to pin point your desire. Also, a lot of wheel shops will steer your to a stock offset which doesn't mount as flush as what the car can handle vs what is stock/safe.
Give some options and I promise you will find great advice. No one is a dick here. But it's hard to give pointed feedback without more info. Post up styles you like, you'll get great suggestions. Budget helps too.
I can't wait to see photos of your car!
Old Mar 1, 2017 | 06:35 AM
Tonyb203's Avatar
Need non staggered. I have 4matic
Old Mar 2, 2017 | 10:07 AM
s4_sh1640's Avatar
2010 E550
Even if you run 20x9 fronts and 20x10 in the rear, i dont think it would be an issue on the car although its a 4matic.
But there have been different discussions and point of view about this. MB wouldn't probably recommend it because they want you to go by the book, but im sure we have so many guys here who run staggered wheels on the 4matics.
Old Mar 3, 2017 | 09:44 PM
Abrown3mtg's Avatar
As I stated in my prior post, width makes no difference. You need to keep the exterior diameter of the tires very close. I mentioned sizes that work. You can read the numerous other threads on this topic and you will find the same answer. You can also call a vendor. I wish you the best of luck. I'm sure you will find something that looks great.
Old Mar 4, 2017 | 01:34 AM
davidjohnbamber's Avatar
2013 E550 Sedan
The tread wear warranty of a staggered versus square rim/tires is something to consider. IMO
