W212 Wiper Motor Wiring Question
Hello Everyone,
The question is regarding the 2015 E350 Wiper motor wiring diagram. I’ve searched on http://www.revbase.com/BBBMotor/Wd for days, but not yet to locate “M6/1” wiring diagram.
I need to test the wiper motor stand alone with voltages. Would like to know if any expert happens to know the operable voltages of each pin (i.e., Slow or Fast mode without rain sensor). I assume there is a combination that I can verify the function of the motor without connecting for the harness.
Thank you for your time~
Have a nice day,
Louis
Have a nice day,
Louis
Hi Plutoe, Thanks for your time to reply my posting. However, not quite understand why VIN is needed and why you said not correct?
What is incorrect? The model to the part? or the year to the part? In fact, this forum generate a VIN decoder link automatically on my posted reply. It is the 2015 E350 RWD, the model I want to know how to wire. Please specify what's incorrect? Thanks~
If you have WIS and do not understand why the VIN is needed to correctly define how the car was built----you have a problem-----go through a variety of WIS docs and you will see comments like "up to chassis number or from and to chassis number" the chassis number is apart of the VIN.
The VIN you posted is not correct--go to your registration and double check that number with the number you posted.
The two drawing numbers I provided will answer you questions on the wiper motor--simply take your time to study the drawings!!
