Black tube with yellow stripe in back of motor
Does anyone know what the black tube with a yellow stripe on it is called?
its on a 2013 e350 v6 i see where it's coming from from the far left side but don't see where it connects to on the far right side of it. I think I've found where it's supposed to connect to but would like to verify before I plug it in. https://cimg4.ibsrv.net/gimg/www.mbw...3d4d6637e.jpeg |
I have an earlier model, but I'll hazard a guess that its a vacuum line. If you pull the air cleaner off, you will have a better view.
Line
I discovered today it's a line part of the intake manifold but it's not sold separately.
Originally Posted by Heisenberg5070
(Post 7112753)
What is the issue or reason you are asking this question? |
(Post 7112211)
Re
Originally Posted by Jerryluna223
(Post 8690182)
did you ever find out what this vacuum line is called or what it does ? Mine snapped from the nozzle on the left hand side of the upper intake .
so that line comes from your main manifold on top, it’s an oil line that connects to a male line on the rear of the engine. |
