Sponsored by: CARiD
Power windows stopped working
Old Apr 25, 2017 | 09:28 PM
Maallen40's Avatar
2017 S550
Hey.... pulled out of the drive through and went to put up my drivers side window and it wouldn't go up. None of the drivers door window switches work although each individual door window switch works. Holding down the lock button on the key fob did bring the window up so I'm thinking the entire drivers door switches are bad. The power folding mirrors and the left and right mirror adjustment also don't work.
Its dark now but in the morning I guess the only thing I can check is fuses...gonna have to track down where or if there is a fuse for this.
Any ideas?
Old Apr 25, 2017 | 09:41 PM
tresean1's Avatar
Veteran: Marine Corps
W212 E-class, W211 E-class, F10 5-Series
while you were in the drive-thru, was it raining, and did the door panel get wet?
Old Apr 25, 2017 | 09:58 PM
Maallen40's Avatar
2017 S550
Nope...not at all...it did rain earlier today but the car has been in my garage all day..I also noticed it doesn't light up like the rest of those switches, so now I'm convince it's not getting any power.
Old May 17, 2017 | 07:52 AM
sidharthg's Avatar
e350
You have a blown 30 amp fuse, just change it and it will be running! hereis the diagram of the fusebox
http://www.autogenius.info/mercedes-...e-box-diagram/
fuse no. 2 & 3, check which one is out. just a $ worth of job! DIY! cheers!
Old May 18, 2017 | 03:14 PM
Maallen40's Avatar
2017 S550
Thanks...I'll check it putt once I get home
