Sponsored by: CARiD
A bit confused if this wheel specs will work
Old May 23, 2017 | 02:10 AM
alamry's Avatar
2014, E350 ,4matic, luxury package, AMG kit
Good Day to All .........well, I've been reading almost all wheels related threads on this wonderful forum and I'm now a bit confused on the so many different opinions on Wheels/Tires specs for our cars, hence I'm in need of your kind assistance on this one dear fellow members.
I have a 2014 E350 4Matic Luxury model lowered on Vogtland springs about 1.6" front and rear.
maybe a mistake that is too late to revert, but I recently went ahead and ordered custom forged wheels:
19x9ET32 front
19x9.5ET42 rear
I'm now worried that I ordered the wrong wheel specs for my car, also what is the best Tire specs combo to go with the above wheels if they'll fit ?
can anyone with knowhow in this area help me please ?
Old May 23, 2017 | 07:24 AM
blegthbloo's Avatar
2013 E550 4Matic
Those wheels should fit... not sure about the tire sizes though. I think 235/40 or 45 up front and up to 275/35 rear is what some guys are running on 19" wheels... but don't take my word for it.
Old May 23, 2017 | 09:22 AM
RA72825's Avatar
You really need to pay attention to the circumference from front to back with your 4Matic or risk burning up the transfer case. I am going to mount some 19" E63 wheels on my 550, but the offsets are more acceptable for larger tires
They are 38ET up front and 52ET out back. I will mount the tires in the following chart and you can see they are almost identical in terms of circumference and revs/mile. The 52ET in the rear allows for the 285 tire to fit whereas your 42ET pokes the wheel out to far to mount this size tire without rubbing. You will need to play around with tire sizes to make sure your staggered setup does not cause issues with your 4Matic
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
245/35-19 3.4in 12.9in 25.8in 80.9in 783 0.0%
285/30-19 3.4in 12.9in 25.7in 80.8in 784 -0.1%
Old May 23, 2017 | 01:44 PM
alamry's Avatar
Thank you for your assistance Gentlemen...my research indicates 235/35/19 front and 275/30/19 rear is the perfect combo in terms of Circumference.
i now hope this wheel/tire combo will fit without rubbing.
Tire Calculator Online: http://tire-calc.com
Old May 23, 2017 | 01:51 PM
RA72825's Avatar
Yessir, that should get the job done. Please post right back in here when you have them on. I enjoy seeing everyone's new set of shoes.
Old May 24, 2017 | 10:18 PM
tresean1's Avatar
Veteran: Marine Corps
W212 E-class, W211 E-class, F10 5-Series
Will the following tires sizes work or cause any damage/rubbing:
255-35-19 front. 285-30-19 rear.
Old May 25, 2017 | 12:09 AM
alamry's Avatar
use this easy Tire Calculator Online: http://tire-calc.com
