Sponsored by: CARiD
P2 code on my 2011 E350
Old Jun 4, 2017 | 11:28 PM
Walter7339's Avatar
E350 Bluetec
I have a P2 code after a battery change. I'm not sure if the battery change caused the problem. Any ideas anybody?
Old Jun 5, 2017 | 11:46 AM
jahquan3's Avatar
2010 E550 P2 w/AMG Sport Package + Pano, 2015 Nissan Pathfinder
What is the exact full code?
Old Jun 5, 2017 | 11:48 AM
jahquan3's Avatar
If it's P0002:
What causes the P0002 code?
The fuel volume regulator range/performance code may have several causes:
Disconnected plug to the fuel regulator
Possible corrosion in the sensor connector
Damage to the sensor wiring to the ECM
Leaking or defective fuel pressure regulator
Damaged fuel pump
The ECM is damaged
Old Jun 5, 2017 | 01:03 PM
raja777m's Avatar
2014 E350 4M Diamond Silver
To OP.
http://www.troublecodes.net/pcodes/
click on the specific code and you'll get more information.
Again, these are generic codes and there is no rule Mercedes has to follow them.
Good luck.
Old Jun 6, 2017 | 12:54 AM
Walter7339's Avatar
E350 Bluetec
Thank you, problem solved.
