Replace cracked wheel...?
Front right wheel has a half inch hairline crack on inside lip, which causes a slow leak of a few psi from the tire.
Can it be safely repaired?
Replacement OEM AMG wheel is approx $1100 new or $900 used.
Discount Tires recommended a full set replacement of 4 aftermarket wheels (so MB emblem can be salvaged onto new wheels) at $232 each ($1050 after all install, tmps, etc...)
So should I buy new wheels & try to sell the 3 old wheels (approx values)?
Thanks,
Thanks,
http://www.rimrepairhouston.com/
NO, NO, NO, NO, NO, NO, NO, NO, NO, NO, NO, NO, NO, NO, NO, NO, NO, NO, NO, NO, NO, NO, NO, NO, NO, NO, NO, NO, NO, NO, NO, NO, NO, NO, NO, NO, NO, NO, NO, NO, NO!
This is what pothole vs tirerack wheel looks like:
Buy the OEM wheel and live freely, not wondering what road will make your wheel explode like my Axis wheel did.
I just had to replace two of them and opted to get older AMG rims that appear to be a little sturdier then the newer versions.
Just canceled order of new wheels at Discount Tires & will go have them fix that tiny crack this wkend...
Thanks,
https://houston.craigslist.org/wto/d...205808352.html
Tire tread is only 15%, so, consider new tires.
Went to a tire/wheel shop a block from office, $100 & 2 hrs later, they welded the half inch hairline crack & guarrantied the repair (at that spot) for life.
My wife's extremely happy to get to keep the AMG wheels...
